Starter Motor Replacement 5.7L V8
Removal
Procedure
Important
This vehicle was designed for
starter mounting without shims. However, if single or double shims have been
added to correct a noise or engagement condition, reinstall the shims in their
original location to ensure proper pinion-to-flywheel engagement.
- Raise and suitably support the
vehicle. Refer to Lifting
and Jacking the Vehicle in General Information.
- Remove the left side oxidation
catalytic converter. Refer to Oxidation
Catalytic Converter Replacement in Engine Exhaust.
- Remove the starter motor bolts.
- Lower the starter motor.
- Remove the engine wiring harness
starter lead nut.
- Remove the positive battery cable to
starter motor nut (3).
- Remove the starter motor.
Installation
Procedure
- Install the starter motor.
- Install the positive battery cable
to starter motor nut (3). Tighten
Tighten
the positive battery cable to starter motor nut (3) to 10 N�m (89 lb in).
- Install the engine wiring harness
starter lead nut. Tighten
Tighten
the engine wiring harness starter lead nut to 2 N�m
(18 lb in).
- Raise the starter motor.
- Install the starter motor bolts. Tighten
Tighten
the starter motor bolts to 50 N�m
(37 lb ft).
- Install the left side oxidation
- Lower the vehicle.
